DII electric start problem
Old May 19, 2025 | 07:41 PM
over-land's Avatar
7th Gear
Default DII electric start problem
Have an off road modded rust free D2 that I would like to keep on the road.
It stat outside for the winter months.
The battery is 3 years old.
Trying to jump the car it beeps consrtantly and it wont jump start .
Suggestions - or is this just a get a new battery moment.
Thanks.
Old May 19, 2025 | 07:56 PM
The Deputy's Avatar
Might need a new battery. Did you try slow charging it with a battery charger? Sometimes, just jumping isn't enough...if the battery has been completely dead for a while.
Old May 19, 2025 | 08:50 PM
Brandon318's Avatar
Before getting a new battery you could first try charging it up with a trickle charger or something similar. I find I have to throw my battery on there every couple months just to top it up with how often it gets driven.
Old May 20, 2025 | 05:51 AM
over-land's Avatar
7th Gear
Perfect! Thank you.
This is what I suspected.
Thanks!
Old May 20, 2025 | 03:31 PM
Harvlr's Avatar
If a really dead battery is your issue, I would disconnect it (maybe just from the negative terminal) and try jumping again. If it still doesn’t work, I’d suspect something more like an immobilized issue.
LR4STL
May 29, 2024 03:04 AM
DiscoUSA
Apr 24, 2017 10:28 PM
simistermike
Jan 3, 2013 10:49 PM
jrkstore43
Aug 7, 2009 06:20 AM
hazletbassist89
May 17, 2009 10:14 PM
