Dii plug wires
Old Jul 30, 2018 | 08:14 AM
Kennyutz8's Avatar
5th Gear
Can anyone show me what the intake gasket looks like? I'm trying to look it up but its showing me 3 different ones and says none of them will fit mine. Also I found a set of 4 hole spray injectors that says it's a performance upgrade. Has anyone installed these and if so what kind of results did you have?
Old Jul 30, 2018 | 08:56 AM
abran's Avatar
Your injectors are 4 hole, the upgrade is for earlier GEMS motors.
Old Jul 30, 2018 | 08:57 AM
OverRover's Avatar
The intake gasket is part #: ERR6621
While you have the intake removed you might also consider replacing the Valve Cover Gaskets # LVC100260 and the Throttle Body Heater Plate and Gasket # MGM000010KG.
Here is what it looks like to remove the Intake and Heater Plate >
Old Jul 31, 2018 | 05:04 PM
Friday Night Disco's Avatar
I have developed a misfire on 3 and I can't see why except maybe the coil pack or wire is going bad. Change out the spark plugs about 6 months ago, so I know they are good. Also not worried about valve cover gaskets as they were replaced 2 years ago.
I wanted to get Gerry's coil pack relocation kit but, not sure I want to spend the extra cash on Tricky Dick.
Thinking of getting the following from ebay:
$12.10 Discovery Upper Eurospare Intake Manifold ERR6621 (QE Autoparts1)
$128.00 Magnecor wire set (Lucky8)
$50.00 Bosch engine ignition coil set ERR6045 (Lucky8)
Old Aug 5, 2018 | 09:25 AM
Kennyutz8's Avatar
5th Gear
Ok guys i need some help. I was able to remove the intake and put in new coils and wires and get it back together with a new gasket but i broke this fitting on top of the intake plenum. Now my truck will fire but will not run. Is this a vacuum line and if so how would i fix it?
stb616
Jan 5, 2019 05:49 AM
redwhitekat
May 4, 2018 06:46 PM
svntsvn
Feb 25, 2015 10:43 PM
aarons02
Feb 25, 2011 12:46 AM
unstable
Apr 27, 2008 12:39 PM
