DII rear wiper blade?
Old Jan 8, 2013 | 03:53 AM
sickws6's Avatar
Default DII rear wiper blade?
My rear wiper does not clean my window that well at all. Are the D1 rears better just like the fronts? More tension on the D1 style?
Old Jan 8, 2013 | 07:55 AM
You would be better off buying a new rear wiper assembly.
Old Jan 8, 2013 | 11:32 PM
sickws6's Avatar
Anyone ever try to replace the tension spring with a higher tension one?
Old Jan 9, 2013 | 07:06 AM
jhill15's Avatar
I have not tried to replace the spring but I have thought about using a front wiper arm instead. Im just not sure if it would wear out the motor due to the weight of the metal arm. It also has way more tension on the spring then the plastic arm. Plus, it would be a nice permanent fix if it worked.
Old Jan 9, 2013 | 07:51 AM
jafir's Avatar
I've used a d1 rear arm. Works great.
Old Jan 12, 2013 | 08:16 AM
hankeester's Avatar
I replaced all three from A.B. and the back wiper was only wiping about half the rear window. 3 months later I accidentally broke the rear blade so I ordered a new one. This one works fine and wipes the entire window.
My thought was maybe I put the first blade on backwards as I think you can install them visa versa but I did not note this before taking the old (broke one) off and putting on the new one.
bcolins
Feb 2, 2014 09:40 PM
photocrimes
May 17, 2013 09:34 AM
JAC
May 9, 2010 04:35 PM
vmann7
Jun 6, 2009 01:12 PM
bigugly82
Apr 4, 2007 06:30 PM
