Dilemma
Old Oct 6, 2018 | 09:41 PM
Mike53's Avatar
Default Dilemma
Hey Guys And galls,I have a question I bought a motor out of a wrecked 03 it has 130,000 I put the new motor in and it runs great,But My question is Iam rebuilding the motor that over heated I pulled the heads off and sure enough the gaskets are toasted so Iam going to put in a new gasket set And I bought a pair of refurbished Heads I just have this Does the trick I hope that the block is okay the top of the pistons show no signs of steam cleaning so what do y’all think?how do I know if the block is ok?I hate to do all this top end work and still have the same problem water in the oil,Before i tore into the motor I texted the compression and Iam in the safe zone it started right up and there was no ticking noises and idled perfectly and it was full of water in the oil it was All the way up the dipstick so if you were in my shoes what would you do?Once I get the motor going Iam most likely am going to keep it as a back up or sell it.
Old Oct 6, 2018 | 10:18 PM
No Doubt's Avatar
#1: Pressure test the block
#2: check the flatness of the block
#3: if you've already pulled the motor and the above 2 tests are good, then drain the oil and open up the bottom end so that you can replace the bearings
#4: rebuild with new bearings and all metal cometic gaskets
Old Oct 6, 2018 | 11:06 PM
Mike53's Avatar
Default Dilemma
Thanks my friend!Were do you get the metal gaskets from?Ive never heard of them?
Old Oct 7, 2018 | 03:21 AM
Mike53's Avatar
Default Compression test
Hey guys,What should the compression test read in a 4.0 boush Land Rover Discovery 2001 what should it read ?iam going to check mine tomorrow to see if the compression is good.Thanks a million Yours truly mike53
Old Oct 8, 2018 | 05:54 PM
Mike53's Avatar
Default Does anyone know ?
[QUOTE=Mike53;664796]
Hey guys,What should the compression test read in a 4.0 boush Land Rover Discovery 2001 what should it read ?iThankd
Old Oct 8, 2018 | 06:38 PM
Extinct's Avatar
Old Oct 8, 2018 | 09:15 PM
Mike53's Avatar
Default Help
No body knows What the compression is in a 2001 Discovery 4.0 boush?
Old Oct 9, 2018 | 06:47 PM
Extinct's Avatar
Originally Posted by Extinct
120-140
THIS
gsxranger
Feb 22, 2019 08:40 PM
Crunkgringo
Aug 23, 2018 11:14 AM
Ben Matheson
Aug 4, 2018 07:23 AM
jaredj
Dec 19, 2014 08:13 AM
bbolin
Mar 17, 2011 11:55 PM
