Ding Ding Ding after suspension conversion....
Guys,
Suspension conversion done, unplugged relay and fuse for the air ride, pulled plugs from the compressor, now when I drive over 1- mph I get an annoying ding-ding-ding the entire time I drive. Hoping there is something easy I'm overlooking...
See attached for one thing that can cause the three dings - SLS paragraph
Also, from electrical manual:
The BCU is making the ding, based on a command from the SLABS. Best fix is have ECU and SLABS re-programmed by shop for coil suspension.
The SLABS ECU provides outputs and receives inputs to/from the BCU on connectors
C0655 and C0504 as follows:
An output is passed from SLABS ECU pin C0655-7 to BCU pin C0660-10 on a WK
wire. This output enables the SLS audible warning.
An input is received from BCU pin C0660-12 to SLABS ECU C0655-12 on a WU wire.
This input is the SLS raise/lower command from the remote handset.C0655 and C0504 as follows:
Last edited by Savannah Buzz; 03-03-2012 at 09:50 AM. Reason: Why encourage bad behavior
bosshogt
12-28-2010 05:19 PM
