Disco 2 ABS
Changed the shuttle valve seals and switches but the ABS pump will not run all fuses and relay check ok. Does the ABS ecu have to be cleared for these functions to operate and the three amigos to go to bed.
What codes were you getting? (The short answer is "Yes", but that might not be the right answer if you have anything other than the 114 error code.)
OK...if they could read the ABS codes, then they should be able to reset them for you and turn off the 3 Amigos. Otherwise, they were guessing and you need to find a person or a shop with a code reader that can actually read/reset those ABS codes. (Hint: The RSW Solutions ABS Amigo might be your cheapest option if you can't find someone who has one of the correct readers for the D2.)
johnkbl
Jan 13, 2009 08:54 PM
