Disco 2 Driveline Questions
Hi Guys,
I'm trying to troubleshoot some driveline noises and need some help. I've done some searches, and still have a few questions.
I've got an 04 D2, which I purchased a couple of years ago. Love it.
Over the past days/weeks, I've been getting some squeaking from the driveline which I've narrowed down to the front propshaft. I'm running a Great Basin Rovers Custom Heavy Duty Driveshaft. I feel like I do a pretty good job keeping it greased - every 3K or so. I'm not sure how to tell if it's the spider, the centering ball, or something else. Unfortunately, I don't have time to tackle the repair myself, so I'm going to take it to my indy, whom I trust reasonably well. I'd just like to point them in the right direction. I've linked two videos which might help.
The first is a video while driving. The squeak is noticeable.
The second is a video from under the truck while up on jackstands. You can see the condition of the shaft, and the u-joints - I don't think it's too bad. I re-greased them today hoping that would take care of the issue, but the squeak persists. As a sidenote, you can see some fluid buildup on the bottom of the truck and transfer case. I know it's a Rover, but is that so much I should be concerned about replacing all the seals in the driveline?
Also there are some grating-type sounds coming from either the transfer case or the CDL. Any thoughts would be appreciated. I'm reluctant to drive very far until I've got a better grasp on what's going on for fear of grenading the transmission/transfer case/exhaust. . .
Thanks!!!
__________________
Thanks!!!
__________________
Normally I'd be thinking 'wheel bearing' but it appears to be coming from underneath in the video.
That's what my driveshaft sounded like when the needle bearings were bad. I couldn't see it with the driveshaft on, nor feel any play in the shift, but it was real obvious when I took it off. Mine was very close to catastrophic failure. I would pull that Shaft and look at the joints very carefully before you drive it.
Disco_Drew
07-27-2007 05:20 AM
