Disco 2 Driveline Questions
Old Jan 25, 2014 | 05:20 PM
MU ///M3's Avatar
Default Disco 2 Driveline Questions
Hi Guys,
I'm trying to troubleshoot some driveline noises and need some help. I've done some searches, and still have a few questions.
I've got an 04 D2, which I purchased a couple of years ago. Love it.
Over the past days/weeks, I've been getting some squeaking from the driveline which I've narrowed down to the front propshaft. I'm running a Great Basin Rovers Custom Heavy Duty Driveshaft. I feel like I do a pretty good job keeping it greased - every 3K or so. I'm not sure how to tell if it's the spider, the centering ball, or something else. Unfortunately, I don't have time to tackle the repair myself, so I'm going to take it to my indy, whom I trust reasonably well. I'd just like to point them in the right direction. I've linked two videos which might help.
The first is a video while driving. The squeak is noticeable.
The second is a video from under the truck while up on jackstands. You can see the condition of the shaft, and the u-joints - I don't think it's too bad. I re-greased them today hoping that would take care of the issue, but the squeak persists. As a sidenote, you can see some fluid buildup on the bottom of the truck and transfer case. I know it's a Rover, but is that so much I should be concerned about replacing all the seals in the driveline?
Also there are some grating-type sounds coming from either the transfer case or the CDL. Any thoughts would be appreciated. I'm reluctant to drive very far until I've got a better grasp on what's going on for fear of grenading the transmission/transfer case/exhaust. . .
Thanks!!!
__________________
Old Jan 25, 2014 | 06:01 PM
FlyingZebra34's Avatar
If it were me, I'd pull that prop shaft out and inspect it when it isn't connected to everything else. I couldn't figure out what was wrong with mine until I did just that (turned out to be the center ball)
Good luck ....
Old Jan 25, 2014 | 06:25 PM
OffroadFrance's Avatar
Good luck ....
+2.............it sounds like a dry bearing. With the shaft out and the CDL engaged then try it on a rolling test, say, about 20-30 mph. If it disappears it's the shaft at fault probably.
Normally I'd be thinking 'wheel bearing' but it appears to be coming from underneath in the video.
Old Jan 25, 2014 | 08:46 PM
Charlie_V's Avatar
That's what my driveshaft sounded like when the needle bearings were bad. I couldn't see it with the driveshaft on, nor feel any play in the shift, but it was real obvious when I took it off. Mine was very close to catastrophic failure. I would pull that Shaft and look at the joints very carefully before you drive it.
Old Jan 26, 2014 | 11:13 AM
MU ///M3's Avatar
Thanks guys, pulled the driveshaft this morning and immediately could tell the centering ball is the issue. Drove a little with the diff locked and no noise. Any issues if I drive a little with the shaft out and the diff locked?
Disco_Drew
Jul 27, 2007 05:20 AM
D2 2003
Mar 16, 2007 11:31 AM
rirover
Jul 4, 2006 03:01 PM
2k2wranglerx
Mar 12, 2006 06:44 PM
LiftedRover96
Feb 7, 2006 10:41 PM
