disco 2 front sunroof motor
Old Mar 15, 2019 | 09:27 AM
lndrover@carolina.rr.com's Avatar
Default disco 2 front sunroof motor
Does anyone no how hard it is to replace the front sunroof motor on a 2000 disco 2. I understand you do not need to remove the headliner, just the plastic piece that runs across the front.
Thanks,
Joe
Old Mar 15, 2019 | 10:42 AM
Red5's Avatar
Easy. I think I just loosened a few of the screws for the map pockets, don't need to remove completely. Helps pull the headliner down a bit and stuff a water bottle or something in the corners while you get to the 3 bolts with a 1/4" ratchet. T6 or T8 or something close, don't remember. Not hard, 20-30 min tops if you are installing a replacement motor.
Old Mar 15, 2019 | 02:23 PM
Richard Gallant's Avatar
I piece of advice, do not close it up until you know the new motor works and opens and closes the sun roof.
Old Mar 15, 2019 | 02:47 PM
OverRover's Avatar
Originally Posted by lndrover@carolina.rr.com
Does anyone no how hard it is to replace the front sunroof motor on a 2000 disco 2. I understand you do not need to remove the headliner, just the plastic piece that runs across the front.Thanks,
Joe
Have at it...…
Carolynsdisco2
Dec 6, 2017 06:37 PM
rickroverover
Jan 7, 2016 08:34 AM
srockrae
Jul 20, 2013 03:31 PM
mlelah
Freelander
Sep 3, 2011 03:02 PM
alanroberts50
Nov 18, 2007 11:56 AM
