disco 2 hand brake problem plz help
Dear All
my disco 2 model 2001 is showing 3 error lights again n again hill decent, ABS & TC. (break is working normal)
and when I push hand brake button with out pulling the hand brake it will go up by it self,it was not like this before the 3 error lights. please somebody help me to solve this issue.
Regards
Regards
Before you replace the hand brake cable, check to see that yours is attached. You can see the end if you remove the boot on the lever. There is a metal frame in the boot. Just squeeze it and work the boot off. It will be obvious when you see it. There is a keeper for the outer cable and the inner cable ends in a metal part that goes in the lever.
To replace the cable you have to take the rear driveshaft off and the back of the brake drum. It is a real pain in the ***.
bcolins
03-23-2016 09:04 PM
