disco 2 hand brake problem plz help
Old May 13, 2016 | 02:13 AM
Saleem B's Avatar
8th Gear
Default disco 2 hand brake problem plz help
Dear All
my disco 2 model 2001 is showing 3 error lights again n again hill decent, ABS & TC. (break is working normal)
and when I push hand brake button with out pulling the hand brake it will go up by it self,it was not like this before the 3 error lights. please somebody help me to solve this issue.
Regards
Old May 13, 2016 | 07:31 AM
mollusc's Avatar
That combination of lights is known as the Three Amigos. There are dozens of threads about them on here -- just search for that.
Old May 13, 2016 | 07:49 AM
Charlie_V's Avatar
My hand brake did the same thing. It is the hand brake cable. I had to replace my cable, which is a surprisingly complicated thing to do.
Look on the Atlantic British. If memory serves, they have a video on it.
That is probably unrelated to your three amigos.
Old May 13, 2016 | 10:22 PM
Saleem B's Avatar
8th Gear
Thank you
actualy i was confused about Hand Brake I thought it is related with 3 amigos as I start geting the both issue it the same time.
Old May 13, 2016 | 11:31 PM
Charlie_V's Avatar
Originally Posted by Saleem B
Thank you
Saleem I could be wrong about that but I'm pretty sure. Maybe someone will chime in.
Before you replace the hand brake cable, check to see that yours is attached. You can see the end if you remove the boot on the lever. There is a metal frame in the boot. Just squeeze it and work the boot off. It will be obvious when you see it. There is a keeper for the outer cable and the inner cable ends in a metal part that goes in the lever.
To replace the cable you have to take the rear driveshaft off and the back of the brake drum. It is a real pain in the ***.
Saleem B
May 16, 2016 07:27 PM
Miwo
Mar 16, 2011 02:01 PM
nick731
Jan 11, 2009 05:42 PM
02Disc02
Apr 22, 2008 10:09 AM
