Disco 2 issues
#21
#23
I often see a catalyst efficiency below threshold code when i'm troubleshooting for plugged catalytic converters. That is a fairly big clue and it is set by the difference between the upstream and downstream O2 sensors. Where it may just be a bad O2 sensor it can also be an actual plugged or bad converter. Not definitive but a good clue as to where to look. Obviously the visual inspection is a better test of the converter.
JohnZo (11-23-2022)
