Disco 2 Shaking A lot at 60mph
Old Dec 9, 2014 | 01:51 PM
ammonation's Avatar
Default Disco 2 Shaking A lot at 60mph
Been having this issue for a few months now...
Basically gets to around 60mph and shakes pretty hard. The shaking feels like it is coming from right under the front seats.
Worth noting, I had the front drive shaft replaced last Spring.
Old Dec 9, 2014 | 01:55 PM
primussucks's Avatar
couple things.
tire balance
front output bearing on the differential
flange on differential (as was the case with my buddies).
All easy fixes.
Old Dec 9, 2014 | 03:49 PM
lordmorpheus's Avatar
Definitely check tire balance. When I had the stock tires on my D2, my vibration at highway speeds made me think something was going to fly off the driveline. My right rear tire was 0.5oz out of balance. Rebalanced all of them and drove smooth as silk afterward.
Old Dec 9, 2014 | 04:34 PM
OffroadFrance's Avatar
Starting with the obvious stuff, tire/wheel balance. Then possibly the drive shafts particularly the front cardan. Also it can be the transfer box front or rear bearings giving out and jumping around, it'll be obvious by oil leaking fron the flange seals. Even the diff pinion bearings can cause vibration when worn a lot.
Finally, engine and gearbox mountings, these are dead and collapse after 10 years and 100K miles. (to check engine mounts it's easy, there is a hole undeneath them, measure the depth using an inverted verner gauge, it they are 20-25mm that's OK if the are less they have collapsed or started to collapse. This collapse doesn't necessarily cause vibration it just makes the ride and engine noise/vibration very harsh.
Start with the easy checks and tasks first and work your way through the list.
Old Dec 9, 2014 | 04:39 PM
dusty1's Avatar
X4 on tire balance check first
Old Dec 10, 2014 | 03:58 PM
ammonation's Avatar
had one of my employees swing by sts tire, guy said don't bother with the balance if the drive shaft wasn't balanced when replaced.
Old Dec 10, 2014 | 04:08 PM
Lowest Bidder's Avatar
Well, that would be the culprit if the vibration started at the same time the drive shaft was replaced. But did you buy a new drive shaft (which should come balanced from the factory) or did you have the u-joints replaced? (in which case it should be balanced afterward)
Anyway that's easy to test. Lock the transfer case and remove the drive shaft (About 15 minutes with the right tools) then go for a test drive. If the vibration is gone then take the drive shaft to a specialized shop to have it balanced. It cost me 85$CAN here to have it balanced here last October.
Old Dec 10, 2014 | 04:09 PM
acamato's Avatar
If the driveshaft was unbalanced when it was replaced, you would have vibrations then. You can look at the driveshaft to see if a weight got knocked off. If theres no indications that a weight is missing. Get the tires balanced.
Old Dec 10, 2014 | 04:30 PM
dusty1's Avatar
or if you have center diff lock pull the shaft and lock it. 2wheel drive test will rule it out
Old Dec 11, 2014 | 09:18 AM
drowssap's Avatar
exactly
