Disco 2 Shaking A lot at 60mph
Old Dec 12, 2014 | 07:27 PM
ammonation's Avatar
mmmm had another employee look at it, little did I know he was a mechanic in the Marines.. Took it for a quick spin, went from axel to engine mount, to tire balance, and settled on what he called u-bolts on the drive shaft.
Old Dec 12, 2014 | 09:52 PM
lordmorpheus's Avatar
And so the verdict is....? U-bolts on the drive shaft?!
Old Dec 12, 2014 | 10:51 PM
dusty1's Avatar
save the marines!!!!
there is no u bolt or u clamp on your truck.
take it to another employee. maybe a former medic
Old Dec 12, 2014 | 11:41 PM
binvanna's Avatar
Panhard rod bushings
Old Dec 13, 2014 | 12:48 PM
ammonation's Avatar
lol... U bolt didn't sound right at all, think he was referring to u joint.
If it is indeed the ujoint, is that replaceable without replacing the whole drive shaft.. again..?
Old Dec 13, 2014 | 01:03 PM
dusty1's Avatar
Yes. 3 ujs and 1 centering ball
The centering ball can be a bear.
Old Dec 13, 2014 | 01:21 PM
What year is your D2? If you can lock the CDL, remove the front drive shaft and take it for a drive to see if the vibration is still there before spending the time and money of replacing u-joints that may or may not be the problem.
Old Dec 13, 2014 | 10:37 PM
ammonation's Avatar
Screwing with the driveshaft is a bit above my head.
Just tossing this out there, it really feels mid-to-rear shaking, I know my back struts are more or less needing a replacement. Could this be it?
Sort of almost sounds like a flat tire at 65mph ha
If you are wondering why i am asking if I cant replace it myself its to "do my homework" in case I have to take it into a shop.
Old Dec 13, 2014 | 10:47 PM
Have you had the tire balance checked yet?
Old Dec 13, 2014 | 10:49 PM
ammonation's Avatar
Had my employee take it to "his guy" at meineke right near our store, he didn't want to bother with balancing was adamant the front drive shaft needed to be balanced since it was replaced last spring.
