Disco 2 Shaking A lot at 60mph
Old Dec 13, 2014 | 11:06 PM
  #21
lordmorpheus's Avatar
I remember you saying that a while back. Screw what his guy at Meineke thinks. Since the drive shaft is new, unless the company that made it did a crap job, or it lost its balance weight, I really don't think that is the issue. Take it to a tire shop and just tell them you want a rotate and balance. I think the going rate is about $40 around here.
If it has been more than 10k miles since you have had them checked for balance, chances are they are out of balance anyway as these wheels (or at least mine) like to throw weights.
Seriously. Balance your tires. Mine was shaking so bad, I was afraid to go over 50MPH on the highway. As soon as I got home, I checked the drive shaft to make sure something hadn't gone wrong with it, then balanced my tires. Smooth as silk after that.
Old Dec 14, 2014 | 11:25 AM
  #22
ammonation's Avatar
Alright I will give that a try, would hate to blow something out in the Rover with these cheap gas prices
Old Dec 15, 2014 | 01:21 PM
  #23
OffroadFrance's Avatar
Before they balance the tires ensure they clean any stones or debris out of the tire treads first. I heard of some drongo who balanced some wheels with stones in them. Of course the owner drove down the road and the stones flew out and the wheels were out of balance immediately. Some tire fitting stations certainly ain't brain surgeons and that's for sure.
Old Dec 17, 2014 | 10:58 AM
  #24
ammonation's Avatar
That is actually pretty god damn funny.
Old Dec 19, 2014 | 12:16 PM
  #25
ammonation's Avatar
****Problem Solved****
  #26
ammonation's Avatar
**tire balancing**
Old Dec 19, 2014 | 01:01 PM
  #27
Good to hear! Glad I kept after you about checking it.
Old Dec 19, 2014 | 04:06 PM
  #28
ammonation's Avatar
Appreciate the help everyone.
Now onto front differential, rotors and brakes.
Old Dec 19, 2014 | 11:35 PM
  #29
Charlie_V's Avatar
I may be too late to be of any help and this may be bad advice, but I had the same problem with a new driveshaft (front) when I called the shop they were amazed that the shaft could have a problem since it was brand new. I sent it back and they called me...
When I took the shaft out of the box from UPS, I lost hold on one end and the shift came apart. I put it back together. No problem... Except I threw the balance and alignment of the joints completely off.
Live and learn for me. I thought I had put it back together perfectly. Not so much.
Old Feb 25, 2015 | 10:15 PM
  #30
ammonation's Avatar
So the problem has returned, tho this time rattling/shaking as low as 40mph.
Figured it was a balancing, took it to STS guy claims he balanced front tires, but noticed my front left tire rod was broken.
Didn't charge me, just gave me a quote.
Kinda feel like he is misdiagnosing the problem, though I don't doubt the tire rod is broken. Rover has been swaying a bit recently.
Anyone?
