Disco 2 Sunroof Won't Close
Old May 20, 2018 | 03:21 PM
jstorz's Avatar
Default Disco 2 Sunroof Won't Close
So my son has decided he loves Land Rover, and I'm learning to work on it. New to us Disco 2 rear sunroof will open and will partially close electrically. Rolls all the way forward but won't fold down. I can use an allen ranch to open it and close it to the same point. Is the microswitch keeping it from folding into the frame or? Thank you
Old May 20, 2018 | 06:59 PM
CollieRover's Avatar
I have no idea, but have you downloaded the Rave Manual?
It’s invaluable.
Old May 20, 2018 | 08:40 PM
jstorz's Avatar
Yep, got that, excellent reference. Pretty good at research, good at rigging. Just looking for insight if motor locks up when microswitch engages.
Old May 20, 2018 | 10:19 PM
No Doubt's Avatar
Before digging in, use the switch to *almost* close the sunroof, then open it back up just the slightest possible amount (i.e. just bump the switch briefly).
Then close it fully with the switch.
Just as a test.
Old May 21, 2018 | 06:54 AM
Red5's Avatar
The micro switch only tells the module to briefly stop the motor at the "vent" position. If you continue holding the button, or release and press again, the motor should continue moving the glass closed or open. You could try putting power directly to the motor and see if it fully opens and closes. If it does, it sounds to me like a flaky module.
Old May 21, 2018 | 01:57 PM
jstorz's Avatar
"No Doubt", thank you, but no joy. "Red5", I notice that it opens with a single button press, but needs to be held to close ( as far as it will go). Front sunroof is working.
Old May 29, 2018 | 08:21 AM
jstorz's Avatar
SO it turns out that the tracks are just 16 years dirty. I pulled a set of tracks from a salvage yard, and cleaned them up to get a feel for how this mechanism works, the tolerances don't allow for much gunk, but considering, it's a pretty good design I guess. So note that you don't have to pull the entire headliner to get at this mess and when the Rave says to "release" a light or fixture, it means take off the clear part and look for an attachment bolt or screw. Otherwise you get to go back to the salvage yard and replace those parts also. A low profile right angle drill head (I like the Klutch brand)will give you access to the screws, just be careful of the drainage tubes.
j33p3r
Oct 7, 2016 05:19 PM
dominiquetx
Mar 9, 2012 11:53 PM
OhioDisco
Mar 6, 2010 11:19 PM
roving patrol
May 20, 2008 01:53 PM
tads
Aug 20, 2007 03:41 PM
