disco 2 ticking
disco 2 ticking
Hi:
I went thru a couple of threads on here discussing various ways of resolving the notorious ticking on these 4.6L engines in the disco 2. Here is what I've done so far:
- did an engine flush (had shell rotella T4 15W40 in) with a Mann filter - used AmSoil engine flush. came out pitch black.
- flushed the radiator, put new coolant in and a new 190 deg thermostat.
- setup ultra-guage to monitor things
I'll attach a link to my running of the truck right after this was done. FYI...truck has just over 70,000 miles. Bought it in Nov. 2022.
https://photos.app.goo.gl/WGHg591poKb3v3Kz9
Does it tick from a stone cold start, or only after warming up? If it does it after warming up, check the exact temp it starts with obd2 temp gauge. Could be a ultragauge or torque app. If it starts below ticking at a temp over 180 or 170, you can put a lower temp thermostat in it. You should also check the oil pressure, the other possibility is that you have a cracked oil pump or walked cam bearing and the ticking is due to low oil pressure and not a slipped liner.
Have a 180 degree one coming shortly which I'll install. I plan to bring it to my local shop to have them test the oil pressure at cold idle and warm at 2000 RPM.
When the engine is cold, no tick present. When it hits right around 180 degrees, the ticking starts. The video showed ultraguage at 183 when I said "now the
ticking starts".
Will post the results when I get these items done.
ticking starts".
If it starts at 183 then you may get lucky and be able to get rid of it by running a bit cooler. If OP is ok you can run a 170 or 160 but will need a 99-02 ECU to keep it from throwing a code with a 170, 160 nothing will stop the code. If ok is low and the cause then hope it is a cracked gear set ( I had one ) as that is an easy fix. Walked cam bearing is more involved.
