Disco 2 wont start after replacing battery
Old Mar 19, 2026 | 10:54 AM
Vialiamslens's Avatar
5th Gear
Is the door code the EKA Code? I've tried contacting 2 different service centers trying to get the EKA code so I can unlock the vehicle that way, but both said that the EKA code is generic for that year so they can't give it to me or I could go and steal other trucks from that year. From what I've seen online the code is tied to each trucks vin so I don't see how it could be generic. Anybody have any info on that?
Old Mar 19, 2026 | 06:16 PM
whowa004's Avatar
it's a like 51515 or 15151 I can't remember exactly but you turn and hold the key in the door one way until the horn sounds and then go between lock and unlock based on the number of times specified and in theory it should "mobilize" the car again. lots of info out there that is more accurate that what I described.
Old Mar 20, 2026 | 07:46 AM
sqlbullet's Avatar
"1515" I am pretty sure is the universal or default code.
Old Mar 20, 2026 | 10:11 PM
Harvlr's Avatar
In North America, not in all parts of the world. I just used it on my P38 today, via the Nanocom
Old Mar 20, 2026 | 11:00 PM
5th Gear
When I hold the key to the unlock position for 5 seconds nothing happens to begin the code entry sequence. When the car is unlocked the security light stays off entirely so I'm not too sure whether the immobilizer is actually the case now. Also the two codes I got after scanning are in the pictures.
Old Mar 30, 2026 | 08:38 AM
ahab's Avatar
This may or may not be relevant at this point but you could jump those two solder points on the broken key fob with a paperclip and trigger an unlock signal.
Old Mar 30, 2026 | 08:55 AM
5th Gear
I did that and it worked to unlock the truck, but it didn't change anything with the immobilizer state. Not quite sure what my next step should be other than maybe somehow tracking down a nano-com to use.
Old Mar 30, 2026 | 09:59 AM
ahab's Avatar
Sorry, I missed that in your post. I have little experience with this immobilizer stuff as well, but I remember reading something about lock/unlock three (five??) times in quick succession. Could be tricky with a paperclip but it might be worth trying.
Old May 10, 2026 | 08:56 PM
Aj6543's Avatar
Was this issue resolved? Curious to the solution?
Moonshinesail
Range Rover Velar
Jul 27, 2024 05:15 PM
umwolverine
May 31, 2024 06:51 AM
ORDPA
Sep 26, 2023 08:35 AM
Mikep70236
Sep 22, 2023 05:07 PM
ggushee
LR2
Aug 11, 2020 09:38 PM
