Disco 2000 Heater core
Old Oct 24, 2012 | 03:33 PM
sstevensonm's Avatar
Default Disco 2000 Heater core
How hard is it to change out the heater core on a Series II
Old Oct 24, 2012 | 03:50 PM
How mechanical are you??
Download a free copy of a Rave CD, shop manual, link below, and follow the directions.
Old Oct 24, 2012 | 04:56 PM
Rovin4life's Avatar
Seriously crappy. You better make sure the core is actually leaking and its not something else. if the floor is wet make sure its not the sunroof and its actually coolant leaking. They royally suck. Order a new set of lines cause they a bolted to the back of the heater box and sealed to it. You have to pull the entire dashboard out. Its a six to ten hour job. Its not fun at all.
Old Oct 24, 2012 | 06:39 PM
lr2001silver's Avatar
Banned
That's craziness a heater core can be done in 4 hours without removal of the dash. And that's 4 hours if its your first time. after working in a shop and doing quite a few I can do one in a few hours now. You will be able to use the same lines if you don't bend them during removal. The aluminum on the heater matrix is soft and so are the lines but if your careful you can manage with out bending them. You will want to buy the heater matrix that comes with new O rings and new clamps. Think about how much of a pain in the **** it would be if you had to remove and replace the lines just to change a heater matrix. That's silly dude.
DancerDeb
Freelander
Jan 16, 2014 02:39 AM
pedronz
Feb 26, 2011 09:43 PM
97DISCOIDAHO
Sep 6, 2006 04:34 PM
97DISCOIDAHO
Aug 21, 2006 12:49 PM
philipm7
Aug 27, 2005 10:12 PM
