Disco did not want to crank
Old 05-02-2009, 09:55 PM
The crank sesnor is on the drivers side of the engine, at the back about half way down.
Just remove and replace.
Old 05-03-2009, 08:28 AM
Here is what you are looking to replace.
Old 05-03-2009, 03:53 PM
cellman01's Avatar
I do not see it. Can you be a little more spacific about the location? Should i be able to see this from the top or do i have to get under it? its probable right in front of my face.
Old 05-04-2009, 11:57 AM
CCROVERSE01's Avatar
I just did this, it is on the drivers side, on the Bell Housing, behind the exhaust pipe.
It has a heat shield (cover) that you need to remove first. When removing sensor, make sure you don't lose the spacers, and put back the same way.
Chels2
03-14-2014 11:39 AM
mbeasom
09-23-2011 02:25 PM
Disco SoccerMom
01-15-2009 11:35 AM
ROLLOVER
04-27-2008 02:01 PM
lrd99
06-29-2007 06:38 PM
Quick Reply: Disco did not want to crank
