Disco Gear/Transfer noise rumble ID
Old Jan 19, 2010 | 01:56 PM
Gronk's Avatar
3rd Gear
Default Disco Gear/Transfer noise rumble ID
Can any body help me identify the likely source of a new noise from my drivetrain?
I have a 1996 Disco 1, manual 300 tdi ES which has just started to make a sort of deep rumble/grinding noise when driving forwards under moderate load upwards. It is not there at light throttle or gentle cruising , but comes in as I increase the power. Also it does not seam to be there on over-run either.
When sitting in the drivers seat it appears to come from the transmission area in the middle.
The external drive parts look OK so I am assuming that it is in the gear box and transfer case.
Does anybody have any ideas of the likely source and how long it will be until it goes completely, or if i will get nay warning ? It is my daily driver so I need to plan the repair.
Thanks
Old Jan 19, 2010 | 02:00 PM
okdiscoguy's Avatar
Most are auto here in the states, but I would suggest you change/inspect the fluid in both. If it is the t-case gears, it could lock up any time..
Old Jan 19, 2010 | 03:35 PM
Gronk's Avatar
3rd Gear
thanks for your response.
The transfer box oil level is OK, next is to check the main gearbox R380 early version.
Old Jan 19, 2010 | 08:34 PM
greg409's Avatar
did you pull your driveshafts?
wiggling the u-joints with driveshafts installed will not tell you if (1) or more are binding up.
It's a pain in the ***, but I'd pull 'em and see how smooth they move.
luck,greg
Old Jan 20, 2010 | 11:23 PM
Gronk's Avatar
3rd Gear
Not yet but will try that.
They were examined by a mechanic, but he did not remove anything, so maybe did not see it properly.
Thanks
jallert
Dec 13, 2009 11:34 PM
range03
Apr 14, 2009 06:33 AM
mattlapper
Aug 8, 2007 09:40 AM
maverick544
Aug 3, 2007 05:54 PM
dbs600
Apr 16, 2007 01:20 PM
