Disco I and II code reader. Please read!
Hi! I have a 95 Disco I, and I have had a lot of problems since I bought it. I need a nice and cheap code reader. Also, I think that I am going to sell this car because it uses gas, and then buy a diesel one.
Could anyone tell me which is the best value for money code reader I can buy? Will it work in a Disco I and II?
Thanks!!
Thanks!!
My 95 Disco 1 does not have a connector for a Code Reader. Rather it has a fault display under the passenger front seat. Poor gas mileage is just a result of needing a good tune up. There is a list on this forum that outlines what you need to do. You should be getting about 16 mpg.
Forget your plans for a diesel if you live in the states. Won't pass emissions in any state, and a conversion costs literally ten times the trucks worth. I've been eyeing that Jetta TDI though...
All vehicles from 96 and newer are OBD2 systems and can be read by any scanner except for ABS, SLS or SRS faults which takes a much more expensive scanner and software.
DiscoBenjamin
Oct 14, 2011 05:53 PM
