Disco II Cargo Door Stuck
I was able to get the door open. The lower arm controlled by the outside handle was not lifting the lock. The lock was stuck in an up position. I was able to spray PB blaster inside the lock and reach inside and move the lever until the door finally popped open. I also put a new green thing on the lower door handle to have a tighter connection with the door handle connector. A lot of time and sweat but it is good now.
Worked for me too
Using the spray helped me open the door immediately from the outside. Thanks for the tip. I also learned that while the inside door handle will lift the lock on one pull and open the door on the 2nd pull, the lock will not move up or down with either the interior lock/unlock switch on the dash or the key. I suppose that indicates a new latch is called for, or is there a chance that after I remove the inside door panel I will find a way to rescue without replacement? I suppose what I'm asking is there a reason to open up the panel before I order the part or might as well wait until I have it all in hand?
jigray3
07-30-2019 07:52 PM
Taken19
09-16-2013 06:19 AM
