Disco II Center Locking Differential Question
Old Jan 1, 2009 | 10:21 AM
  #21
Urban Panzer's Avatar
Default RE: Disco II Center Locking Differential Question
probably the best way to look at it m8
Old Jan 1, 2009 | 10:54 AM
  #22
ORIGINAL: Urban Panzer
ORIGINAL: Disco Mike
ORIGINAL: Spike555
ORIGINAL: mrossipir
Spike 555, my 3 amigos are on...
I just confermed this with Urban Panzer, when the 3 amigos are on you will have limited ABS and no traction control.
Just a come back to this post, if the trio is on, you, there is no grey area, you either have ABS or not, there is no limited ABS function. Depending on the combination of ABS codes your ECU might have on will determine if the ETC works, and better then 90% of the time the ETC and Hill Decent are out of operation.
If off road with the trio on, if the ETC is working, you will hear it clicking and see the ETC flashing as it works.
Not correct.
If you have the 3 amigos because of a shuttle valve switch failure, the ABS will still work but the deceleration threshold is increased. this is one way to tell that you do have shuttle valve switch issues rather than wheel speed sensor faults.
The ETC is disabled at all times the 3 little buggers appear
Sounds like I need to do some reading.
Thanks for the information. Is that only on the 03 qnd 04's or all D2s?
Dean
Mar 25, 2015 10:46 AM
saidrover
Feb 15, 2013 08:42 PM
workingclass
Sep 19, 2008 06:34 PM
workingclass
Sep 19, 2008 03:14 PM
audiurq
Jul 1, 2007 11:52 PM
