Disco II cranks, but won't start.
Old Jan 11, 2019 | 10:02 AM
jmacster's Avatar
Default crank position sensor
i had this happen, easy fix
get a code reader, you will need it
Old Jan 11, 2019 | 01:19 PM
Evanblanc's Avatar
Thanks. Will install new sensor today and report back.
one more question: flashers will come on still when turning key to position 2. Could the cps fault be doing this or is something else faulting? Mind that I am 99% sure this has nothing to do with alarm/ immobilizer as using key fob unlock turns off red alarm light completely and re arms when locking so I'm assuming this is functioning properly.
Old Jan 11, 2019 | 05:25 PM
Evanblanc's Avatar
Installed brand new Bosch crank sensor. Still exact same issue. Where to next?
Old Jan 11, 2019 | 07:38 PM
Evanblanc's Avatar
Note: flashers still come on when entering key position 2, before even attempting to crank. What are all possible instances that trigger flashers along with no start. I know the inertia switch will do this, should I check somewhere else down the line of this switch as it is brand new? What else will trigger flashers?
side note: bcu cinnections/ ground look fine and are super clean
Neil Warnes
Aug 13, 2018 12:25 PM
PPK Zombie
Oct 6, 2014 12:06 AM
edwhittle
Feb 5, 2013 08:48 AM
dynomite
Sep 4, 2012 07:42 PM
castillo8071
Nov 13, 2007 10:54 AM
