Disco II cranks, but won't start.
Thanks. Will install new sensor today and report back.
one more question: flashers will come on still when turning key to position 2. Could the cps fault be doing this or is something else faulting? Mind that I am 99% sure this has nothing to do with alarm/ immobilizer as using key fob unlock turns off red alarm light completely and re arms when locking so I'm assuming this is functioning properly.
Note: flashers still come on when entering key position 2, before even attempting to crank. What are all possible instances that trigger flashers along with no start. I know the inertia switch will do this, should I check somewhere else down the line of this switch as it is brand new? What else will trigger flashers?
side note: bcu cinnections/ ground look fine and are super clean
