Disco II Gearing
Old Apr 21, 2014 | 10:47 PM
corbinwalp's Avatar
Default Disco II Gearing
I currently am geared at 4.75 with airlockers and 255/85/16 tires. I don't typically do too much highway driving so this isn't normally a problem, but at 70mph I'm hitting 3200-3300 RPM. Is this too high? and what can fix this? 4.11 gears, smaller tires, etc.
Thanks
Old Apr 21, 2014 | 10:59 PM
Dane!'s Avatar
That's too high for sure.
Bigger tires or 4.11's gears. I'd go with 4.11's personally. LR stuff wont hold the a big tire, especially the size you'd need with 4.75's. Did you buy the truck with those gears in or did you install?
Old Apr 22, 2014 | 01:37 AM
ScreamingLife's Avatar
4.11 gears are dying, 4.12 are your best bet. There is some 4.14 gears floating around as well.
Old Apr 22, 2014 | 06:26 AM
drowssap's Avatar
unless your on a 1/8 mile 4.75 are a bit much.
Old Apr 22, 2014 | 06:36 AM
corbinwalp's Avatar
Yeah I bought it with those installed, so am I understanding that larger tires will lower my RPM and smaller tires will worsen the problem?
Old Apr 22, 2014 | 07:23 AM
drowssap's Avatar
sounds like it was built just for crawling
thehun
Mar 28, 2025 06:54 AM
Lord Wert
Apr 19, 2013 03:45 PM
elrocha69
Jul 14, 2011 02:50 PM
tango123
Jun 2, 2009 04:32 PM
