Disco II pass door won't open
Old Jan 16, 2008 | 09:08 PM
brooksa's Avatar
Default Disco II pass door won't open
2004 Disco II SE7, still can't get the passenger door open?? can hold lock up while trying handle and can feel it pulling the lock down but door will not budge? Any suggestions?
Old Jan 16, 2008 | 09:48 PM
Default RE: Disco II pass door won't open
So it wont unlock? Try the key in the door to unlock it.
I am betting that the lock acuator is bad.
Old Jan 16, 2008 | 10:18 PM
Just thought of something else to try. Disconnect the battery, if the door actuator doesnt have power it wont try to lock the door.
Old Jan 16, 2008 | 10:26 PM
skyguy's Avatar
won't removing battery power kill the radio code?
Old Jan 16, 2008 | 10:51 PM
brooksa's Avatar
There is not a key slot on the passenger door? I can try the battery disconnect but will it kill the radio?
Old Jan 17, 2008 | 08:57 AM
You have the code for the radio dont you? But yes disconnecting the battery will "unplug" the radio and you will have to put in the code.
If you dont have the code the dealer can get it for you. I guess its just how bad do you want to open the pass door?
Old Jan 17, 2008 | 09:02 AM
raid13's Avatar
if its the right front.
if you can't open the door from the inside door handle and
the handle cable in not broken you need a door latch assembly.
right rear might be a child lock issue with the outside door handle not working.
Old Jan 17, 2008 | 10:05 AM
brooksa's Avatar
I will have to call dealer for the radio code because I do not have it. It is the passenger front door, ca't get it to open from inside or outside. ugh
Old Jan 17, 2008 | 04:23 PM
okdiscoguy's Avatar
ORIGINAL: brooksa
I think there is a return spring on the lock mechanism that looses its juice.... My pass rear door is the same way and the front has done it a couple of times now. I don't think it is the actuator because the lock comes up and goes down fine, just doesn't release the lock to open the door. I too feel the little almost catch of the handle. If I hold the lock up, it will go ahead and open. I am probably tackling this over the weekend. I'll let you know what I find....
Old Jan 18, 2008 | 07:23 AM
brooksa's Avatar
ok thanks for everybody's help, I plan on opening , somehow, this weekend.
PPK Zombie
Aug 16, 2015 10:35 AM
qdog123
Freelander
Jan 15, 2007 11:15 PM
adowgiert
Mar 1, 2006 08:05 PM
saltyrover
Feb 20, 2006 04:39 PM
