Disco II - replace abs module - Los Tres Amigos 'final solution'?
Old Jan 19, 2016 | 03:09 PM
jamieb's Avatar
Thanks! Hope my 3 allen bolts aren't the PITA I hear they can be. I'll be ready with a socket option.
Old Jan 19, 2016 | 05:33 PM
stuckntx's Avatar
Cut the Allen wrench and it will make it much easier.
Old Jan 19, 2016 | 09:16 PM
mln01's Avatar
Some argue that if you are going to the trouble of pulling out the shuttle valve switches you should go ahead and replace them and also replace the shuttle valve seals with the improved ones sold by Falconworks. The argument is that the switches and seals are likely to fail so just do everything while you have the modulator torn apart.
I understand that argument but I am a tightwad. My truck wasn't a daily driver when I did the Option B mod so I elected to take it apart and test and inspect the switches and seals, thinking that I could afford to have the truck out of commission for a week if a problem with the switches or seals was identified.
The switches passed the resistance test and there was absolutely no evidence of brake fluid having leaked by the seals. I rolled the dice and put everything back together doing the Option B bypass only. Next month will be five years with no repeat appearance by The Boys from South of the Border. If only I were so lucky gambling with Powerball.
bostongrun
Nov 14, 2015 09:55 AM
dgi 07
Apr 21, 2011 04:37 PM
maxman
Nov 29, 2010 11:19 AM
alanroberts50
Sep 27, 2009 01:53 AM
StevenDiscoII
Aug 7, 2009 08:18 AM
