Por fin se fueron los tres amigos!!!
Old Nov 13, 2015 | 10:44 PM
bostongrun's Avatar
Default Por fin se fueron los tres amigos!!!
I finally got rid of the 3 Amigos, I changed the shuttle valve but I ultimately had to do the bypass where the and yellow and green wire is rerouted. After, I completed the procedure i still had the 3 Amigos but it was because I spliced into but did not bypass the green and yellow wire, I cut the wire and the Amigos went away hopefully forever,
The first time, I had a hard time getting the air out of the brakes, they say you have to use the Hawkteye Tool to open the Shuttle Valve but this time I used a $20 Harbor Freight One Man Brake Bleeding Tool and got a nice firm pedal, All you need to do is just keep pump the tool until you don't see any bubbles in the transparent plastic tube.
One thing, I don't think it's possible to remove the Shuttle Valve while the ABS Module is in the car. I see that others have done it but I couldn't; I can see the advantage of it: no need to bleed the brakes and risk stripping the six soft aluminium threaded ports in the ABS Module but Its a real PITA to get those 3 Allen Screws out. Be careful with the 6 ABS connectors; don't cross thread them.
This forum is great, people all over the World helping each other out for no $, just a desire to help one another,
Old Nov 13, 2015 | 10:57 PM
cappedup's Avatar
Agreed. Great resource. So helpful.
It is possible to remove the shuttle valve without unhooking the Wabco unit. It's tricky, and I had to use a very odd arrangement of sockets, adapters, but now I can whip the shuttle valve off in about 6 minutes. I can see why you might think it's not easy enough and pull off the brake unit though.
Well done getting it fixed.
Old Nov 14, 2015 | 09:55 AM
mln01's Avatar
I was able to complete Option B without removing the modulator but I have girlie-man hands. It was tedious but doable. The girlie-man hands also came in handy when I changed plug wires a few years ago.
tylor36
Oct 18, 2013 08:51 PM
Rmendole
Sep 11, 2012 06:15 AM
dgi 07
Apr 21, 2011 04:37 PM
Disco_Fever
Sep 4, 2009 06:12 PM
StevenDiscoII
Aug 7, 2009 08:18 AM
