Disco II Tires
Old Feb 21, 2011 | 05:42 PM
scottmehl's Avatar
3rd Gear
Default Disco II Tires
Has anyone put wheels/tires from a newer range rover on a disco II. I want to put 19" Continental Cross Contact 255/50/19 with load rating 107 on my 2001. Checked for previous threads with this topic but didn't see any. Any thoughts appreciated.
Old Feb 21, 2011 | 06:03 PM
yloDiscoII's Avatar
Found this by google-ing...
Old Feb 21, 2011 | 06:27 PM
jhewitt1111's Avatar
I know there is a pic on here on the saudi grill thread. It has two dII's with RR sport rims. At least 20's.
Old Feb 22, 2011 | 12:22 AM
roverDII's Avatar
Yes, it can be done.
You will need the lug nuts to those wheels and HUB centric rings to keep them from causing Vibes on your steering.
Old Feb 22, 2011 | 02:27 PM
scottmehl's Avatar
3rd Gear
Thanks - knew about the lugnuts -- anything else you can tell me about the "hub centric rings" comment? Haven't heard this yet.
Old Feb 22, 2011 | 02:47 PM
Bundu's Avatar
Banned
This should clarify hub centric:
http://www.justforwheels.com/hub-centric-rings.jsp
Old Feb 22, 2011 | 10:29 PM
scottmehl's Avatar
3rd Gear
Got it - one last question, to be sure. Aligning the rims with just centering lug nuts is not good enough, and the hub centric rings lock down the rims in a better way.
Bundu - really appreciate the time.
Old Feb 22, 2011 | 11:48 PM
mwindth's Avatar
scottmehl,
You are correct...you want your wheels to be "hub centric" not "lug centric"...fill the gap
Alex_M
Nov 22, 2018 12:53 AM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
bikingteacher
Sep 16, 2010 06:44 PM
RoverDude71
Mar 2, 2009 11:03 AM
