Disco ii wont start after warm up.
Old Mar 27, 2016 | 11:11 PM
Charlie_V's Avatar
Originally Posted by cappedup
Something is heating up and altering the scene in fire triangle terms
That's the key. And I can't think of anything that does that.
I recall I kept getting crap running and a knock sensor code once and then, driving down the highway, I saw smoke under the hood. The wire was against the manifold and burned through.
Also, some wires came loose on the highway and shut down the engine, brakes, lights, etc. Everything electrical went dead at once when some other wires touched the exhaust manifold. That was real exciting on a two lane highway at 2am, with a ditch and construction cones to my right.
But those things wouldn't get better when it cooled down. I'm stumped.
Old Mar 28, 2016 | 08:17 AM
3crguy@gmail.com's Avatar
4wd High
Nope havent ran obd code reader, on two accounts. 1 i dont own one, two cant go to parts place and hook up cause then id have to stay for a few hours! I also read something about a fuel temp sensor. Im with you guys its air fuel spark simple, i know i have spark so i kinda ruled out faulty crank position sensor that i just put in being deffective, i have Not checked cam position sensor nor did i know of one to check.
Old Mar 28, 2016 | 08:38 AM
cappedup's Avatar
With something this mysterious, every clue helps. There could be a code hidden which is literally the answer.
I'm guessing you don't have an orange 'engine light' lit, top left on dash? If not, double check the bulb lights at start up.
Old Mar 28, 2016 | 09:20 AM
4wd High
No engine light i do get a service engine soon light up but stopped after i switched plugs now is clear at start up might pop back on while driving but clears away also.
Old Mar 28, 2016 | 09:28 AM
cappedup's Avatar
You have to get the codes read. Your engine is trying to tell you the problem.
Old Mar 28, 2016 | 10:52 AM
Charlie_V's Avatar
A code reader will also show pending codes that may not blossom into a service engine light.
Old Mar 28, 2016 | 11:10 AM
4wd High
Yup, im going to see if i can borrow one from a buddy and do it later today but now that mondays back and have yet to figure out how to live and enjoy life without a 9-6 the rover must wait till tonight. Thanks guys ill keep yall posted.
Old Mar 28, 2016 | 02:02 PM
number9's Avatar
before i get bashed for not
havent ran obd code reader ......... i dont own one
Sould be bashed for not owning tools to work on your D2.
Old Mar 28, 2016 | 02:14 PM
4wd High
Ahh the troll, every forum has one!!
disconic
Jun 4, 2016 02:57 AM
atikovi
Mar 27, 2016 09:05 PM
gustav23
Dec 15, 2011 01:12 PM
Darover
Aug 28, 2007 03:01 PM
riemer
Jan 27, 2007 12:42 PM
