Disco Mike or others with help on bell housing bolts
Old Mar 22, 2009 | 07:38 PM
MarvelVT's Avatar
Default Disco Mike or others with help on bell housing bolts
I am in the process of dropping my transmission and I've run into a problem. The top 3 or 4 bolts in the bell housing seems to be impossible for me to remove. I can barely even find them with my hand and if I am able to get a tool to reach it then I don't have room to use the tool to remove them. Does anyone have any suggestions or experience with removing these bolts? Your help is greatly appreciated.
Old Mar 22, 2009 | 07:56 PM
Andy just replaced the engine on his DII and said that those bolts were impossible to reach but he got them, even harder to re-install.
Look him up and send him a PM and maybe he can help.
Old Mar 22, 2009 | 09:05 PM
unimoged's Avatar
You mention a "tool" that you are using. What is this tool?
You need a socket, u-joint, 30 inch extension and a ratchet or an air gun.
That will take care of the upper bell housing bolts.
Old Mar 23, 2009 | 10:45 AM
handsome rob's Avatar
They are a little tight yes but doable. I used a shorty 9/16 closed end wrench to get them off on my RR, I also needed it to face with the swing towards me and had a lot of grunt to get them to move.
Old Mar 23, 2009 | 10:54 AM
MarvelVT's Avatar
Thanks you guys for all your help. I woke up fresh this morning and attempted it with the u-joint adapters and extensions. For a couple of them I used two adapters which makes it awkward but yes doable. One smashed pinkie and a ratchet to the forehead later I have them off, haha, thanks everyone.
Old Mar 23, 2009 | 09:53 PM
discodefender's Avatar
sorry to be sarcastic, but if you can't get the bolts out, you might have some problems on the rest of your project. Yes, they are a pain in the ***. Sleep on it. It will only take ten minutes tomorrow. Things always work that way when they are frustrating.
Dogwood
May 3, 2015 09:53 PM
caymandrew
Apr 25, 2013 07:26 AM
TripleThreat
Mar 12, 2013 03:23 PM
FrFghtrBRET
Oct 25, 2011 05:40 PM
telly
Mar 20, 2007 03:02 PM
