Disco "Must Haves" for New Owners
Old Feb 28, 2013 | 11:11 AM
sloan74's Avatar
gas money....lots of it...lol
Old Feb 28, 2013 | 11:51 AM
drowssap's Avatar
Triple a
Old Feb 28, 2013 | 02:19 PM
mark d's Avatar
Default "must have" button stickers?
Supersport, where do you get those buttons stickers? I must have me some.
Old Mar 2, 2013 | 12:08 PM
Bravo11's Avatar
Originally Posted by primussucks
i've got a set of 18s with 265/65 BFG A/T with about 60-70% thread left.. PM me if you are interested in acquiring them.
Same ones you have on the "Share Your Measurements" thread? Your truck looks like what I have in mind for mine. They're even the same color.
Old Mar 2, 2013 | 12:10 PM
Bravo11's Avatar
Already learned that the hard way! $100 to fill up with Chicago gas.
Old Mar 2, 2013 | 12:16 PM
Bravo11's Avatar
Originally Posted by Yoops Racing
All depends on what you want to spend....Stock is stock no frills no performance gains but least costly
Tires, wheels, lift, driveshafts and any mechanicals motor, transfer case, leaks all phase 1
and the list just grows from here.....ask me how I know.
I'm definitely in Phase I (great way to look at it, BTW). I just got it back from a thorough checkup and plugs/wires replacement. Everything else checked out OK, just a miniscule valve cover leak . Next up is the front driveshaft rebuild.
Old Mar 2, 2013 | 12:24 PM
Bravo11's Avatar
What??? Why would you say it "probably needs" all that just because the tires are worn?
Isn't that a bit like saying "I'm out of windshield wiper fluid, so I guess I'd better replace the windshield?"
The truck has 84k miles, steering components and brakes are still good. The tires were still serviceable, but they were POS all-weather passenger car tires. First big snow we had I skidded around like a hockey puck, so it was time for an upgrade.
Old Mar 2, 2013 | 01:03 PM
Robert Booth's Avatar
I bought my 2004 Disco 2 SE7 in January.
Without wanting to be the harbringer of doom, here's my absolute must-do list based off of my experience:
Triple A (Broke down twice on the way home from buying the truck, first time free tow 80 miles to friendly land rover dealer, second time replaced the battery)
Tires - (like you i have 18's. Just get the BG Goodrich AT's and be happy about it.)
turn your spare tire holder upside down OR buy the adapter plate from Atlantic British to mount the full seize spare (you did buy a full size spare right ?)
Front Driveshaft - Inspect, service or replace. Mine had been replaced previously but it was not balanced correctly and causing a disconcerting vibration at 40mph. I replaced mine with a Tom Woods heavy duty shaft as I also have an OEM lift on the truck.
Code Reader - Your Disco will throw codes. I got about 1800 miles into my ownership before i wised up and now leave my OBD2 cable permanently attached to the port
WD40 & Lubricant - First car i've ever owned where my rear door lock jammed up from road grime. prevention is better than having to fix it by removing all of that rear trim when the lock is too badly gummed up for the "pop off the badge and spray" fix to work.
I have about $3000 into my Disco2 that i payed top dollar for in January (my truck was represented as being fully serviced and ready to go). I don't mind doing the work because then i know its been done and i'll have a better baseline for the future.
The reason i'm telling you all of this is that i also bought the truck thinking that my $6000 after-sale budget would go towards the winch bumper, rack, air lockers etc. Instead, i'm spending money this year to make the car as reliable as I can, then next year i'll start adding on the fun stuff.
oh did i mention that my replacement engine had 70K on it (similar mileage to yours) and that my indy rover mechanic noticed that the Head gaskets have started to leak ?
jycsalas
May 23, 2019 03:02 PM
paintpollz
Jul 17, 2013 02:16 PM
Sam95disco
Feb 25, 2013 08:49 PM
RYAN3326
Jan 23, 2013 08:40 PM
Disco Mike
Jun 21, 2012 09:32 AM
