Disco stalling out... Need help!
So this is the situation, my 03 Disco is starting up fine in the morning. I drive about 1-1.5 miles and the truck stalls out. When I try to start it again it turns over fine. It just wont start. About 30-45 minutes later it will start right back up again. Then after 20 minutes idling or another 1-1.5 miles of driving it dies again. Seems like this is an endless cycle. It was a little low on oil when this happend the first time, as i had just gotten back from a road trip and was heading out to get the oil changed. My oil light did come on AFTER the first stall, but was extinguised with a quart or 2 top off. i though maybe it was the fuel p[ump, but after replacing that and the gasket last night, i discovered that was not the problem. Started up, idled for 20 minutes and died. I am at a total loss right now. Can anyone help?
The most likely suspect...
http://www.roverparts.com/Parts/ERR7354G.cfm
Does your tachometer move when you crank the engine?
Well i don't know if i can afford to take that bet... let me check my wallet.
So I do have another question, how is the replacement done? Is it an easy pull and replace or is there more to it? Is there any other things it may be? I know the tach does work when it's running, does that make a difference? I ask because you guys asked if the tack moved when it was turned over.
Thank you again!
Well thank you guys again. I'll be replacing the sensor as soon as I can get up there. Probably next weekend, but i'll let you know if that was it. I appreciate the help a ton, and knowing my Disco... i'll be asking for help again. Can't tell you why I love her so much when I have to stick so much time and money into her.
RoverJess03 (05-03-2019)
