Disco stalling out... Need help!
Old Jul 6, 2010 | 11:36 AM
bmonkey4201's Avatar
7th Gear
Default Disco stalling out... Need help!
So this is the situation, my 03 Disco is starting up fine in the morning. I drive about 1-1.5 miles and the truck stalls out. When I try to start it again it turns over fine. It just wont start. About 30-45 minutes later it will start right back up again. Then after 20 minutes idling or another 1-1.5 miles of driving it dies again. Seems like this is an endless cycle. It was a little low on oil when this happend the first time, as i had just gotten back from a road trip and was heading out to get the oil changed. My oil light did come on AFTER the first stall, but was extinguised with a quart or 2 top off. i though maybe it was the fuel p[ump, but after replacing that and the gasket last night, i discovered that was not the problem. Started up, idled for 20 minutes and died. I am at a total loss right now. Can anyone help?
Old Jul 6, 2010 | 11:39 AM
Bundu's Avatar
Banned
The most likely suspect...
http://www.roverparts.com/Parts/ERR7354G.cfm
Does your tachometer move when you crank the engine?
Old Jul 6, 2010 | 11:46 AM
Yup, bad crank sensor, this is classic signs of it.
It gets hot and fails, it cools and works again.
You can get it locally so call around.
Old Jul 6, 2010 | 12:46 PM
7th Gear
Default Hmmmm....
I'll have to check that out and get back to you. might not be till this weekend sadly... I have the truck up at my buddy's shop. i appreciate the help though and I will definitely get back to you either way.
Old Jul 6, 2010 | 01:27 PM
I am willing to bet you 100 million billion dollars that is the problem.
Old Jul 6, 2010 | 02:02 PM
7th Gear
Well i don't know if i can afford to take that bet... let me check my wallet.
So I do have another question, how is the replacement done? Is it an easy pull and replace or is there more to it? Is there any other things it may be? I know the tach does work when it's running, does that make a difference? I ask because you guys asked if the tack moved when it was turned over.
Old Jul 6, 2010 | 02:10 PM
Bundu's Avatar
Banned
If your crank position sensor has failed then the tach does not move when it will not start. It's a simple swap, 2 bolts, 2 nuts, one plug and some bitching.
Old Jul 6, 2010 | 02:40 PM
Yes it is a simple R&R.
Looking at the engine in the 3 o'clock position at the back of the engine.
Old Jul 8, 2010 | 02:31 PM
7th Gear
Default Thank you again!
Well thank you guys again. I'll be replacing the sensor as soon as I can get up there. Probably next weekend, but i'll let you know if that was it. I appreciate the help a ton, and knowing my Disco... i'll be asking for help again. Can't tell you why I love her so much when I have to stick so much time and money into her.
Old Jul 8, 2010 | 08:00 PM
The rest of us have the same problem, love/hate relationship with our trucks.
drayrover
Sep 21, 2010 09:44 PM
bmonkey4201
Jul 6, 2010 12:26 PM
ruggles
Jun 2, 2010 07:41 PM
DISCOVERY182
May 12, 2009 11:40 AM
Rover5150
Dec 10, 2007 07:55 PM
