Disco Won't Start
Old Feb 7, 2013 | 01:39 PM
MattyMatters's Avatar
Default Disco Won't Start
Hello all, again.
Matt here:
2002 Land Rover Discovery SE
150k miles
The truck started overheating on me a few weeks ago. I walked it home and swapped out the water pump, the thermostat and the thermostat to water pump hose assembly. Before doing the job, I sprayed a bunch of engine cleaner all over the block to clean it up a bit. Rinsed everything off, cleaned what I could get my hands on and swapped out the above parts.
Put it all back together and tried to start it and nothing. It has power, crankshaft rotates and has a brand new Starter.
Sounds loud when attempting to start.
Oh where oh where to begin? Crankshaft Position Sensor???
thanks for your response.
Matt
Old Feb 7, 2013 | 01:43 PM
jfall's Avatar
Click the FOB five times to unlock and lock and unlock the rover.
See if that helps.
Also -
check any wires you remembered you removed for doing the job.
Old Feb 8, 2013 | 01:30 AM
Pull off a plug wire, attach a spare plug, lay on mainifold, crank and check for sparks. No sparks could be CKP sensor.
Check to be sure fuel pump runs for a couple of seconds when key turned to position 2. Won't keep running unless engine is turning and ECU knows it.
Old Feb 8, 2013 | 08:43 AM
Do you currently have a check engine light on, if so get the codes read and get back to us so we can better help you.
Old Feb 8, 2013 | 08:55 AM
Some parts stores actually rent/loan code readers. Or if a pal has one, it will usually work (OBDII has been standard for many years).
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jan 17, 2014 09:19 PM
Mountain State Rover
Jun 29, 2013 02:06 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
