Disco won't turn over
Old Jul 21, 2022 | 09:08 AM
Triddell62's Avatar
Default Disco won't turn over
Started normal in the morning, stopped by the gas station and as I was leaving it wouldn't start. battery is charged, all dash lights come on till I try to start it like they usually would. The is no clicking, no cranking, just silence as I turn the key. Anyone have any idea of what could be wrong.
battery connection is good with no corrosion.
Fuses I could check at the moment we're okay
Old Jul 21, 2022 | 10:08 AM
ahab's Avatar
You can try smacking the starter to see if that has any effect. Do the dash lights go out when you try to engage start?
Old Jul 21, 2022 | 10:25 AM
Triddell62's Avatar
the dash lights do go out when I try to start
Old Jul 21, 2022 | 12:56 PM
mollusc's Avatar
Mine sometimes does this. Try shifting into neutral, then back into park, then turn the ignition off and back on again. May have to try a couple of times. I think it's related to an XYZ switch that's very slightly out of alignment.
Old Jul 21, 2022 | 04:20 PM
Triddell62's Avatar
Guess this was the problem
slammed it into Park and it started
SundayFunday
Jan 7, 2021 06:00 AM
JEFIII
May 5, 2018 06:38 AM
Ursula
Feb 9, 2017 05:18 PM
timpugliese
Jan 17, 2015 08:34 AM
Ollie839
May 9, 2011 09:36 PM
