Disco won't turn over
Started normal in the morning, stopped by the gas station and as I was leaving it wouldn't start. battery is charged, all dash lights come on till I try to start it like they usually would. The is no clicking, no cranking, just silence as I turn the key. Anyone have any idea of what could be wrong.
battery connection is good with no corrosion.
Fuses I could check at the moment we're okay
the dash lights do go out when I try to start
Mine sometimes does this. Try shifting into neutral, then back into park, then turn the ignition off and back on again. May have to try a couple of times. I think it's related to an XYZ switch that's very slightly out of alignment.
slammed it into Park and it started
