Disco2 not starting, anyone in thw Sheboygan, WI area that wants to help?
I parked my 99 Discovery 2 up in the woods at my house a couple months ago. Tried starting it later and wouldn't start. I crawled under the truck to look at the starter and the wire going to the starter had pulled off the little tab. I reattached it but still nothing. Key turns on normal lights on dash, can here the relay clicking when key is turned and hazards turn on. I moved relays around so don't think it's the relay.
I think its probly the starter but since the wire was pulled off, just curious of any other suggestions before I replace the starter... Wondering if I can use a jumper cable or something like that and attach it from the battery to touch the starter to at least see if the starter is the issue...
I replaced the battery.
Any thoughts or people local to Sheboygan that wants to come by and help?
Thanks
Thanks
Here's the link to my thread from last year on the topic, in which Richard Gallant and harvlr solved the problem.
https://landroverforums.com/forum/di...em-dead-118947
Buzzwalburg
01-02-2012 07:55 PM
