Disco2: weird dome light issue
The auto dome light function is tied into the ignition somehow....I'm sure it is explained in the RAVE. Ohh, and their is NO door switches.
so it has to be tied to the actuators; breaking a ground I assume.
I think I caused a dead short when I replaced the rear hatch actuator last week; I am going to pull it open and see if I didn’t pinch a wire between the actuator and the door jam.
Doc
Yes, the actual "switching" on of the dome light is due to the door actuators, the ignition part I was referring to was when the lights are auto dimmed after a door remains open, then you turn the ignition on, the lights will come back on if I remember correctly. The ignition will over ride the auto dim
Discovery_Scott
01-08-2012 11:42 PM
