Disconnected battery
Old 04-10-2013 | 11:32 AM
slabrat's Avatar
Default Disconnected battery
I disconnected my battery and removed it to do my head gasket job and clean everything . Is this the wrong thing? I remembered reading something about disconnecting the negative only? Or was that a dream?
I saw the post about a battery that was out for months and the ECU had to relearn everything?
If it is out for awhile does it throw up some codes until learning is over? I have looked for this info but can''t find it anywhere.
Started HG job last night going slow but not bad so far.
THX
Old 04-10-2013 | 12:05 PM
drowssap's Avatar
you can take it out if you want I just disconnected the ground from the head. As long as it is not out form any substantial time you should be fine
Old 04-10-2013 | 01:42 PM
slabrat's Avatar
Probably a couple of weeks By the time I get heads out, and sent out, brought back and reinstalled it could be a couple of weeks or longer
Old 04-10-2013 | 01:44 PM
If it will be out of the truck for a couple of weeks, place it on some wood, not metal or on the ground cause that tends to cause the battery to discharge pretty quick.
Old 04-10-2013 | 01:51 PM
slabrat's Avatar
I set it on wood on top of rubber Plus I have a charger
Old 04-10-2013 | 01:52 PM
You are covered.
Old 04-11-2013 | 01:40 PM
SuperSport's Avatar
As far as the ECU re-learning everything, this is not such a bad thing. I used to do a "Hard Reset" to my Jaguar every once in a while when things were acting up. It would clear up MANY issues we had with the Jaguars. Windows not working quite right, Sunroof not working, Rough Idle, and many other electrical issues. Not just the ECU, but BCM, TCM, etc... It effectively clears the Memory. It's kinda like when your personal computer starts acting up, sometimes the best thing is to reset it again.
After replacing the battery, IF the ECU has lost it's memory, expect it to run strange for a couple minutes until it resets things. On the Jaguar, it took about 1 minute for it to reset the Throttle Position Sensor and Throttle Body, so it would idle high and low for a bit. It also re-learned the Adaptive Electronic Steering and Transmission Shifting. All of this took a few days to learn again.
I just did a "Hard Reset" to my Discovery today, but have not had a chance to drive it yet to see if it made any difference. I don't have a stock radio, so I didn't have to deal with the security code if it came up.
Old 04-11-2013 | 02:16 PM
slabrat's Avatar
Thanks!
I wish rebooting would stop leaks I wondered if there would be some things run better or worse for awhile.
I have an after market radio in the 99 so it won't be a problem Just have to reset stations.
The 04 has a code issue I hope to be able to resolve this weekend. I bought the 04 to doll it up a bit and drive it like a grocery getter. Right now it gets 86 miles a day to work and back. Boring with out a radio.
cheqbay1997
03-01-2018 09:23 AM
KernowDiscovery
02-17-2016 04:24 PM
fezzr
03-18-2012 01:20 AM
VCO
10-17-2011 10:07 PM
aremee
09-30-2006 06:47 PM
