Discovery 1 Switch Panel in D2
Old Nov 3, 2025 | 07:54 AM
gte619n's Avatar
Default Discovery 1 Switch Panel in D2
Guys,
I am looking to add some additional switches to my D2. I know the D1 had the neat two and three gang panels where our coin tray and ashtray is currently. Are these direct swap-in? If not, has anyone ever swapped them over?
Original part number is AWR3330LNF.
Thanks!
E
Old Nov 3, 2025 | 10:48 PM
nashvegas's Avatar
Yep, that fits. It used to be a common modification.
Just know if you put it in a facelift 03/04 the fascias are black so it doesn’t match the color. Better for 99-02 in other words, if you care about such things.
Old Nov 4, 2025 | 09:36 AM
H Hill's Avatar
Where do you get the switches? Part #?
Old Nov 4, 2025 | 09:57 AM
gte619n's Avatar
I've been finding a lot of them on eBay. Some of the supports are cracked. Once I get a decent bracket, I'll do a 3D model and post it.
Do these just slot right into the ashtray and coin area? What about the push/pop mechanism that they use. Does that need to be removed/broken/modified?
Thanks,
E
Old Nov 4, 2025 | 12:42 PM
gecko951's Avatar
The D1 panel works but the switches aren't standard so I opted to 3d print this panel which fits in the same spot and uses carling switches.
https://www.thingiverse.com/thing:3930500
Old Nov 10, 2025 | 10:10 AM
gte619n's Avatar
Hey guy, got it all installed. I am big time switched up now:
The brackets are a little hard to find with tabs intact, so I CAD'd up one:
https://www.thingiverse.com/thing:7196432
E
Old Nov 10, 2025 | 01:33 PM
nashvegas's Avatar
A great modification !
nashvegas
Mar 29, 2023 05:45 PM
mbrewer110990
Mar 21, 2021 08:57 PM
abran
Jun 12, 2018 09:35 AM
Trail-Tailor
Jan 5, 2016 04:18 PM
Rock Sing
Jun 13, 2014 02:54 PM
