Discovery 2 2001 - Cannot Make Brakes Work
Old Nov 1, 2025 | 07:59 PM
JRN2024's Avatar
Default Discovery 2 2001 - Cannot Make Brakes Work
Need someone with D2 brake knowledge to help me figure out why I cant get the braks to work at all pedal all the way down.
It all started changing pads never opened the line backed up the piston on left side, never had rakes after that.
Decided to then replace both front calipers with new ones.
Bleed all 4 corners manually and with the bleeder pump.
Bought I Carsoft Multi System Diagnostic scanner the thing supports Jaguar / Land Rover but the D2 model listed is the diesel model I have not idea why absolutely worthless.
ABS light is now ON bled brakes multiple times still no brakes none. Runs great just has no breaks and I cannot figure this out.
Any suggestions would be appreciated in some logical step by step approach.to finding out what is the problem.
Thanks!!
Old Nov 2, 2025 | 04:30 AM
frostythor's Avatar
you may need a nancom, to do a power bleed if the ABS light is on then you may have an air lock in the ABS unit
Old Nov 2, 2025 | 09:10 AM
Best4x4's Avatar
20ft of speaker wire and a toggle switch = you can power bleed a D2. Remove ABS relay put the wire in the front/back terminals flip the switch & ABS pump will run.
Old Nov 2, 2025 | 10:33 AM
frostythor's Avatar
yes you can bleed the ABS as you say, but having a nancom would help to identify any other faults , so beg, borrow or hire one if you can
Old Nov 2, 2025 | 01:43 PM
Best4x4's Avatar
ABS faults won't keep you from bleeding the system. Also ABS faults won't make it NOT stop. You just won't have the ABS function. Also I know this is a dumb question, but you did install the proper caliper onto the proper side correct? For proper bleed screw orientation.
pagoda
Dec 1, 2025 12:36 PM
Eljefe2020$
Oct 22, 2025 03:45 PM
jfall
Nov 23, 2016 05:17 PM
Rlozano
Jul 2, 2016 09:56 AM
pottzie
Aug 10, 2012 05:58 AM
