2001 Discovery 2 - Brakes
Old Oct 18, 2025 | 06:43 PM
Eljefe2020$'s Avatar
4th Gear
Exclamation 2001 Discovery 2 - Brakes
I m looking for advise because I cant get my brakes to work. It all started when I replaced the front pads one one side I did not open the line to back the pistons just back them up with the tool. After that no brakes. I replaced both calipers new since. I bled the system with a pump made to bleed brakes, no brakes. Is the problem air in the line, ABS master cylinder? I am at at loss Help!
Old Oct 19, 2025 | 06:14 PM
Extinct's Avatar
I do a gravity bleed followed by a power bleed and it gets all the air for me, but you might find it easier to do a manual bleed.
Old Oct 19, 2025 | 06:33 PM
redrover75's Avatar
There is also the potential that you need to fire the ABS pump to help clear the air. I have had to do it sometime, and have not had to other times. Easy enough, just get 20' of wire and plug into the fuse box, you can find the directions pretty easily.
Old Oct 22, 2025 | 03:45 PM
The Deputy's Avatar
When you pushed the caliper cups back in...did you remove master cylinder reservoir cap? If not, you could have ruined master cylinder. Excess fluid has to escape the reservoir...or it can blow seals in master cylinders plunger shuttle valve...and leak into vacuum booster.
graym
Jan 6, 2025 12:09 AM
Christian Pearce
Jul 19, 2019 07:51 AM
haasri
Jul 1, 2016 09:47 AM
modem7890
Feb 13, 2013 09:13 PM
Tony Crosland
Oct 5, 2012 02:44 PM
