Discovery 2 - Aluminum Overflow Tank
Old Dec 31, 2019 | 09:38 PM
Best4x4's Avatar
Happy New Year Abran!
Old Jan 2, 2020 | 01:50 PM
robert.juric's Avatar
Does anyone know if it is easier to cap off the line with this tank if you've done the TBH bypass?
Old Jan 2, 2020 | 02:00 PM
Sixpack577's Avatar
It will be done the same way.
Old Jan 2, 2020 | 02:04 PM
Best4x4's Avatar
Reservoir has the same amount of nipples on it. So the line from the intake manifold nipple to the reservoir = same setup.
Old Jan 2, 2020 | 02:26 PM
It would be sweet if you could replace the nipple with a bolt. I'm currently using a short piece of hose with a bolt and a clamp and have noticed it started to develop a small leak.
Old Jan 2, 2020 | 02:30 PM
Sixpack577's Avatar
Why not just put a rubber cap and clamp on it?
That, or have the aluminum nipple tig welded closed.
Old Jan 2, 2020 | 02:50 PM
I couldn’t find a rubber cap at the time. I know I could weld it, I was just hoping maybe they made it customizable in that aspect.
but I like your ideas either way.
Old Jan 2, 2020 | 03:00 PM
Best4x4's Avatar
I run a 5/16 line from the intake manifold to the reservoir. I have a black thermal spark plug boot protector over the line where it sits above the exhaust manifold. I have that setup on 3 D2’s and it works excellent.
Old Jan 2, 2020 | 03:26 PM
Sixpack577's Avatar
That's what I did too^
Old Jan 2, 2020 | 03:34 PM
Friday Night Disco's Avatar
Same here, zero issues with the set up
