Discovery 2 coolant leak bottom of radiator
2000 Discovery 2 with little over 1k
Hi, just noticed my rad is leaking. I looked around and it appears as though it's seeping out the bottom of the rad itself. I don't see any leaks from lines, hoses or other areas. It started yesterday and it's a good leak. Emptied half my resevoir.
Could the rad itself be leaking from age? Any thoughts before I spend my day pulling it out?
see Land Rover Discovery Radiator 1999 2000 2001 2002 2003 2004 4.0 V8 | eBay
and repair of the aluminum rad is not worth it. May also have plenty of this inside, see pix. Consider replace thermostat with an OEM one at same time. Don't want little holes in the top to get clogged. See pix.
ZMonet
06-24-2016 04:00 PM
texdisco
07-06-2015 08:34 PM
