Discovery 2 coolant leak bottom of radiator
Old Apr 11, 2012 | 10:52 AM
toofaroffroad's Avatar
Default Discovery 2 coolant leak bottom of radiator
2000 Discovery 2 with little over 1k
Hi, just noticed my rad is leaking. I looked around and it appears as though it's seeping out the bottom of the rad itself. I don't see any leaks from lines, hoses or other areas. It started yesterday and it's a good leak. Emptied half my resevoir.
Could the rad itself be leaking from age? Any thoughts before I spend my day pulling it out?
Old Apr 11, 2012 | 10:57 AM
drowssap's Avatar
go to autozone, advanced or whoever you buy your parts from amd borrow/rent a preasure tester.
Without the system being full, properly blead and under preasure your are waisting your time.
Also you can find that Rad on ebay for $150.00 and that is about as cheapest you will ever find it.
Old Apr 11, 2012 | 11:03 AM
see Land Rover Discovery Radiator 1999 2000 2001 2002 2003 2004 4.0 V8 | eBay
and repair of the aluminum rad is not worth it. May also have plenty of this inside, see pix. Consider replace thermostat with an OEM one at same time. Don't want little holes in the top to get clogged. See pix.
Attached Thumbnails Discovery 2 coolant leak bottom of radiator-dexcool.jpg   Discovery 2 coolant leak bottom of radiator-land%2520rover%2520thermostat%2520005.jpg
ZMonet
Jun 24, 2016 04:00 PM
texdisco
Jul 6, 2015 08:34 PM
iandemel
Mar 26, 2015 01:18 PM
amytre75
Freelander
16
Aug 26, 2013 09:10 PM
Rob145
Jul 28, 2010 07:56 AM
