Discovery 2 Crankshaft seal - Corteco 15030309B
Old Oct 5, 2024 | 03:04 PM
RA122125's Avatar
Banned
Default Discovery 2 Crankshaft seal - Corteco 15030309B
Thought I put this out there for those who maybe struggling with a Crankshaft shaft seal leak. I've had an ongoing very small leak since I got my Disco years ago. I've already replaced the timing cover when I did the oil pump, and after that I'd replaced the Crank seal with the LR OE version, twice. I had also speedi-sleeved the Harmonic balancer with the second OE seal, which helped, a lot, but a small leak still came back a few days later.
So, I did my research thing, trying to see if there was a better fix. I saw someone somewhere refer to the fact that the Corteco seal was a smaller diameter, but I couldn't find any actual info to confirm it, so, I bought one to find out for myself.
Yep, this seal is much tighter on my sleeved Harmonic balancer shaft, and, after a couple weeks driving, I still have no leaks. I took a couple pics to demonstrate the differences in the seal spring, which are blatantly visible...
LR OE seal on top, Corteco seal on bottom. Obviously a noticable difference in spring diameters...
Corteco P/N 15030309B
I did not think to measure the Corteco seal before I put it in, but I did find it reported to be 1.917" inner diameter.
I measured the LR OE seal that I removed from my Disco to be a 1.935" inner diameter.
Perhaps my 9 month old used seal was opened up wider than when I put it in, I don't know, but I think it's pretty easy to see why it was leaking from those measurements.
I'll keep an eye on it, and report back if/when it starts leaking again. But for now, this seal has already lasted longer than any of the OE seals I wasted money on. Hope that helps somebody....Good luck guys 👍
Old Oct 5, 2024 | 06:20 PM
Harvlr's Avatar
Thanks. And also report back in a few months if it’s still dry.
Old Oct 6, 2024 | 10:09 AM
Brandon318's Avatar
Can confirm, Corteco seal installed here 30K miles ago and dry as a bone.
Old Oct 6, 2024 | 11:20 AM
disco96sd's Avatar
Suggest a speedy sleeve too
Old Oct 6, 2024 | 01:01 PM
RA122125's Avatar
Banned
If it helps, for reference, the correct Speedi Sleeve is this one:
SKF 99192
Amazon Amazon
jasonstaczek
Sep 12, 2023 01:58 PM
Charlie_V
Dec 8, 2015 08:43 AM
humroot
Jun 21, 2012 10:51 AM
outdoor7or24
May 21, 2012 08:34 AM
gplandrover
May 20, 2011 02:48 PM
