Discovery 2 lug nuts - M12?
Old Nov 2, 2015 | 06:03 PM
Patrick Duffy's Avatar
Exclamation Discovery 2 lug nuts - M12?
Hi I just bought a set of steel wheels listed for Discovery 99-04. Also the matching lug nuts listed. They arrived and the wheels have the correct centers but the nuts they sent are M14s. The nuts on my 2000 SALTY Discovery are M12s. Currently the wheels are the standard 18 alloys and have Landrover nuts - M12s.
Can anyone clarify if they built vehicles with different nut sizes and which years?
Old Nov 2, 2015 | 08:00 PM
Alex_M's Avatar
They all have the same nuts. I've seen some people slap on steelies with factory nuts, might try that. Otherwise you might find some nuts at your local auto parts store to fit.
Old Nov 3, 2015 | 06:28 AM
drowssap's Avatar
i believe steel wheel take different nut that cast
Old Nov 3, 2015 | 09:02 AM
jafir's Avatar
Disco 1 is M16x1.5
Disco 2 is M14x.15
If they sent you nuts for a D1 the will be too big.
Old Nov 3, 2015 | 10:43 AM
Default Issue sorted - Atlantic screwed up
Originally Posted by jafir
Disco 1 is M16x1.5
Disco 2 is M14x.15
Of course when the nuts were too big I measured the core and it was 14mm. Of course the correct measurement is 2mm bigger as it goes tot eh seat of the thread - dummy! So that is why I thought my studs must be the next size down. Seems that the 4 packs of nuts they sent me are M16. I got a set from NAPPA that will work in the end and have a outside thread for a plastic screw on cap.
Old Nov 4, 2015 | 08:57 AM
WNYErikDiscoII's Avatar
Former Sponsor
Whatever you do, do not use your stock lug nuts on steel wheels. They are not designed for it.
Stock part # is ANR3679
You need to use ANR4851
dcarr1971
Feb 8, 2013 08:16 AM
rsomp
Jun 14, 2012 12:45 PM
bcolins
May 13, 2011 01:31 AM
ronguiteau
May 24, 2010 11:36 PM
mddearing
Jul 21, 2008 09:08 PM
